Hi folks.
I have an HD video camera, but don't have a Blueray player or burner. So, for the last couple years, I've just been burning the HD video as regular DVD video in 16:9 format.
Anyway, I've been using the free tools that come w/ Vista to do this (Movie Maker and DVD Maker). I'd like to move away from these tools for a couple reasons:
- I've run into some encoding problem recently using DVD maker (the encoding process just hangs)
I'm tire of not being able to control the bit rate of the output video
So, could somebody point me at a faq or howto on how this could be done with free tools? I have the video imported from the camera as both dvr-ms and mpeg files, in 1080i format. I want to take those files, author and burn them.
Thanks!
if you want to move up to a better editor, sony vegas movie studio platinum works with avchd cams. it's not free but not a pro level expense either. HD editors that work well are kind of scarce and mostly very expensive.
Well, I'm burning in DVD video format, so I don't need an HD editor. I could down-convert the 1080i video before editing.Originally Posted by minidv2dvd
With all the swell tools out there, I'm assuming I can do this without spending any money (although I will, if need be). -
<<<--- Over there in the margin, Click on 'Tools' under 'Lists' and you might just find what you're looking for.
I realize that. I'm hoping there's a FAQ or HOWTO, so I don't need to try X different products in Y different combinations.Originally Posted by olyteddy
Best utility and procedure to modify DVD
By cryptowiz in forum Newbie / General discussionsReplies: 4Last Post: 3rd Dec 2011, 09:59 -
correct procedure to edit camcorder dvd using NLEs
By codemaster in forum EditingReplies: 1Last Post: 13th Dec 2010, 00:57 -
Cropping Video (Best procedure) ???
By Datahead in forum EditingReplies: 5Last Post: 7th Jul 2009, 19:53 -
DVD Shrink with DVDStyler Procedure?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 6th Sep 2008, 12:52 -
Special DVD creation procedure
By Nick/Athens in forum Newbie / General discussionsReplies: 9Last Post: 29th Nov 2007, 00:13
