I have a movie(avi) that plays perfectly. I tried encoding it to a mpeg1 vcd file using many programs such as Xing Mpeg, LSX Mpeg, bbmpeg, TMPEGenc, and a few others, but all of them would complain about some wrong format. I got around to trying Panasonic Mpeg Encoder and it worked great except that the audio would slowly get out of sync with the video. Then I tried avi2vcd v.4 and it suggested that I should decompress the audio. So I did, but all the programs I've mentioned do not want to encode it.
I cant find anymore mpeg encoders on the net, so Im stuck. Any suggestions? I'm stuck in the mud w/o a rope.
OK, I am able to convert the video from avi to mpeg, but not the audio. Now I just need to find a program that will convert the audio.
Suggestions??? -
Extract the audio as a WAV file with VIRTUALDUB then use as the audio source using TMPGE.
www.vcdhelp.com/virtualdub.htm
Output Color Problem
By apparition in forum Video ConversionReplies: 13Last Post: 12th Nov 2009, 14:45 -
Audio Receiver Problem with HDMI Output
By The Monkees in forum Newbie / General discussionsReplies: 4Last Post: 12th Aug 2009, 02:59 -
WMP11 wont play some MKV files-problem (choppy audio output only)
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 31st Jul 2009, 08:09 -
DVI output problem
By 1234567 in forum DVB / IPTVReplies: 35Last Post: 22nd Feb 2008, 13:11 -
Captured Output Problem
By MrLuck in forum Capturing and VCRReplies: 0Last Post: 12th Jul 2007, 21:17
