This Xvid video clip was captured from Australian cable TV. It is typical of many imported videos where (I think) the FPS is roughly converted to 25fps for PAL, and who cares about the cable customer !!
The video clip shows an aircraft in flight, and notice the jitter or stuttering in the close-up of the blue cabin. If you load this clip into Virtual Dub and walk through it frame by frame, you will see the problem immediately.
Questions
1) What is this called, and how is it caused ?
2) Is there anything we can do to correct it, especially since it has already been screwed by converting it to 25fps (in other words, I cannot use software to perform a conversion from its native fps to 25fps), or better still, leave it at its native fps ?
frozen%20in%20flight.avi
Jitter during transition in and out...
By Huntr777 in forum MacReplies: 18Last Post: 15th Jul 2011, 13:51 -
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 01:32 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 21:35 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 02:21 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 15:09
guns1inger
