i have a lot of subtitles that need to be converted to another framerate (they go out of sync gradually), but subtitle workshop doesn't automatically detect framerate of opened subtitle. is there any software that can do this?
	What kind of subtitles? Some subtitles are frame number based, some are time based.
	SRT has no frame rate. It uses timestamps. Probably the best thing to do is look at the last subtitle and locate the corresponding time in the movie. Then use the stretch function in Subtitle Workshop to adjust the timing.
	ok, thanks.
 and what about .sub?
 how can i "read" their framerate?
	IDX/SUB? I don't deal much with those but I suspect the same method will work. The IDX file is plain text. You can edit it with Notepad.
	There's a plain-text .sub format, too. I've never really dealt with it, and don't have any subtitle files around I could convert to .sub just to take a look at the format, but I think this is probably it: http://en.wikipedia.org/wiki/MicroDVD
 That one does appear to be frame-based.If cameras add ten pounds, why would people want to eat them?
  Any way to determine is something was altered?By droidgrl10 in forum Newbie / General discussionsReplies: 2Last Post: 19th Apr 2012, 09:49
  Converting a "variable framerate" to constant framerate?By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05
  How do I convert xvid framerate 23,967 to xvid framerate 25.000?By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 18:57
  determine which playlist to takeBy KlintIstwood in forum Blu-ray RippingReplies: 2Last Post: 14th Apr 2009, 16:01
  How do I determine the framerate of an FLV file??By lurky in forum Video ConversionReplies: 2Last Post: 13th Aug 2008, 01:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
