Hi,
I have dowloaded one movie which size is 8GB, so it required dual layer to record. I want to see if I can burn into two regular dvds by selecting diffrent video parts and copying all IFO files in both.
Is it possible?
-Miral Patel
Not that way, no. You can't take apart a DVD and move the parts around to two different discs. But you could extract to a MPEG with VOB2MPG, then split the file and reauthor it to two discs. You would loose the menus, though.
Or run it through DVDShrink and you could shrink it or split it to two discs there. http://www.dvd-guides.com/content/view/48/59/
Those are a couple of the easier ways.
you can also do this with dvdremakepro (keeping and manipulating full menu structure but like the poster above mentioned, this app also is payware
8gb dvd burning failed
By renz_007 in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2011, 10:08 -
8gb ps3 vob file to 2 dvd?
By conjure in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2010, 03:15 -
8GB mkv file burned to DVD+DL
By ck_kent in forum Blu-ray RippingReplies: 10Last Post: 24th Mar 2009, 22:21 -
Splitting 8GB DVD into 2 single layer dvds
By omega_weapon in forum ComputerReplies: 4Last Post: 16th Aug 2008, 12:17 -
Burning an 8gb vob file to dvd??
By skyxx in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2008, 18:31
