    Aug 2009
    Canada
    RE; VHS/Beta Tuner MPEG2 from capture Card to Compress to Smaller File; HELP
    Hi gang,
    My 1st post here.
    I am bewildered and awed at the breath of knowledge (and options) here and have much to learn.
    I installed a MPEG card TV Tuner card in my PC and transferring older VHS 9and Beta) types into Digital files. At this point it is doing about 900 Megs Per hour as a file. I think it saves it as a Mpeg, if I read right
    My Question is this;
    Waat Easy-to-use software can I use, hopefully with a GUI that will take a 3 Gig Mpeg file (or any file really..) and compress it/ make it smaller without noticeable loss of Quality ?
    Thanks in advance
    nice to be here
    Take care
    Jean
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Not gonna happen(with no quality loss).
    Author and burn your captures to DVD (good quality DVDs too like Taiyo Yuden or Verbatim)
    or get a bigger hard drive to store them on until you are ready to burn....or later compress WITH quality loss.
