Hi There,
I have a Sony DCR-HC90E which i've been using with a Raynox DVR-5000 0.5 Super wide angle for years..
Would i benifit from upgrading to the Raynox HD-5050PRO, 0.5x, Super Wide Angle Lens ?
This is more expensive and made for HD which my camera is not but i am thinking its better glass so will i get a better picture or it the one i'm using more than good enough for my camera ?
Any advice much appreciated
Also it is the 37mm Raynox HD-5050PRO, 0.5x, Super Wide Angle Lens i am looking at, is this the correct one for my Sony DCR-HC90E with 30mm filter size ? the lense doe's come with step up rings
Stacks
i assume you looked at the comparisons of the 2 at the raynox site? the new lens provides a much sharper image and would be a benefit to any cam over the 5000. as to whether it fits your cam, you'll need to do that research, but i would guess it does.
Thanks Minidv2dvd,
I went ahead and orderd it earlier so thanks for confirming it was worth spending the extra bucks..
I checked with the guy on bhphoto & said it was the right one for my cam so hopefully it turns up intime for my shoot.. 50 frigging bucks postage too !
HD Mini DV camera suggestion?
By alange5 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Jul 2011, 13:51 -
I need a mini CCD pinhole camera.
By Dittoz in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2009, 21:20 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
Fix wide-angle distortion ?
By yukon33 in forum EditingReplies: 3Last Post: 10th Feb 2008, 20:24 -
Can this work ? DVR Wide Angle Converter on an HD Camcorder ?
By thecuban in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Jan 2008, 12:38
