I have some clips to convert to DVD, the original resolution is 512x384. Should I go to 720x480 or 352x480 ?
512x384 in a 720x480 frame would leave you with the wrong aspect ratio (assuming a square pixel source). You'd have to scale to ~560x384 and pad to 720x480 or 704x480. You might as well just scale to 704x480 and use sufficient bitrate.
What he said....Originally Posted by jagabo
That's what i would do. -
If the movie was much over 2 hours I'd consider 352x480 to cut down on the bitrate requirement.
And you're going to have to re-encode no matter what. Since you said "clips", I'm thinking SHORT length, so I'd have it stretched to 720x480 (assuming the 512x384 is 1:1 PAR and deinterlaced)
Scott -
If you have 3 of those clips, I personally wouldn't go to 352x480, but if you have more more than 3, that might be your best choice for quality. You could always try both and see what you like best.
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 11:34 -
Bitrate 720x480 vs 352x480 concept question
By CaZeek in forum Capturing and VCRReplies: 15Last Post: 8th Oct 2010, 13:08 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 14:43 -
352x480 Half D1 Mpeg2 to Divx - How do I keep proper aspect ratio (40:33)?
By stizz in forum MacReplies: 16Last Post: 8th Feb 2008, 02:24 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50
