Hello,
I am here once again rsrs
I have the following problem when command convert my videos to the server with ffmpeg
Code:Unsupported codec (id = 0) for input stream #0.0
The command I'm using is the following:
Code:ffmpeg -i video.avi -ab 128k -ar 44100 -b 800k -r 25 -qscale 5 -s 480x360 -f flv video.flv
Anyone know tell me what can I do to correct this error, as tested on my machine and work properly, tested on the server worked with a video in avi and the other were not sure
Well, I think I have the codec installed, because I that converts a file type on the server and it converted without any errors but the file was small, now with a larger file that has this error there, because I did an installation of ffmpeg in my server, and sends the binary to it, I do not know because it only works with certain conversion, and also realized that after I convert the video I try to open my browser and does not open, but when down to my machine it opens normally.
Anyone know tell me why not run in my browser and the other videos from other sites and I do not run. -
Unsupported codec (id=86021) for input stream #0.1
By noctrine in forum ffmpegX general discussionReplies: 3Last Post: 9th Feb 2012, 09:13 -
FFMPEG Unsupported codec (id=86018) [i.e. AAC]
By kdigit in forum Video ConversionReplies: 10Last Post: 1st Mar 2011, 10:01 -
rmeditor unsupported codec, how to cut rmvb ?
By kclgad in forum EditingReplies: 3Last Post: 7th Apr 2009, 06:38 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13
