Is there someway to open mp4s in virtualdub without having to install codecs in window?
Results 1 to 11 of 11
You can try the vdub mp4 plugin, or directshow plugin. There is a list of plugin links if you scroll down:
https://www.videohelp.com/tools/Virtualdub
You might still need to install the proper vfw codec for decoding to see a picture
Or you can try avidemux, which has internal splitters decoders (not reliant on system installed ones), and offers similar functionality to vdub -
Yes it's buggy and not consistent for me too (I prefer to use avisynth)
Are all the plugins in the correct folder?
AAC is in the audio configuration, not vfw video configuration (but that shouldn't cause no picture showing)
Are you saying the video doesn't play in a directshow player, like MPC? You need a directshow mp4 splitter, avc decoder and aac decoder.
The last 2 you should have if you set it up correctly, for a mp4 splitter look here. To register the .ax you can use radlight filter manager, graphstudio, or the command prompt manually (but this shouldn't affect vdub, which doesn't use directshow, it uses the vfw system) -
Yeah, but i prefer to install (into windows) as little as possible.Originally Posted by poisondeathray
I put the mp4 in the "Plugins32" folder.Originally Posted by poisondeathray
Actually, it doesn't work in windows media player - it seems to get the size of the clip because it resizes the window to that, but it remains black - and it contacts microsoft to find something to play the sound but that failsOriginally Posted by poisondeathray
However I tried MPC and it plays the clip back fine.
I tried the MP4InputDriver.vdplugin from your link, and virtualdub (1.8.5) stopped giving me errors, but it playbacks the video all black (ie nothing there) and no sound.Originally Posted by poisondeathray -
Yeah, a long time ago. And as I remember it only works with a lot of odd scripts as well?Originally Posted by johns0
I like small footprint. But the less i have to reinstall when i reinstall windows the better (usually once a month) -
You only have to use a very small script to open mp4 with avisynth-
save as file.avs and open the file.avs with virtualdub.Code:DirectShowSource("c:\file.mp4")I think,therefore i am a hamster.
How to open .MP4 files in virtualdub? (i want to sharpen mp4
By fuc847 in forum Video ConversionReplies: 27Last Post: 22nd Apr 2015, 08:06 -
MP4 Plugin For Virtualdub
By MourningStar in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2011, 18:10 -
mp4 can't display in virtualdub 1.9.9
By 60xt in forum Video ConversionReplies: 1Last Post: 11th Jul 2010, 00:15 -
MP4 and virtualdub?
By capman21 in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2010, 00:20 -
VirtualDub....save as .mp4
By Ogilvy in forum Video ConversionReplies: 2Last Post: 19th Mar 2010, 23:29
