  1. Hi
    Im converting a blu-ray film from MKV to blu-ray using tsMuxerR 1.10.6 and then shrinking down to a DVD9 my problem is when ive done this and burn and play the film i get a huge green band at the bottom of the picture, im obviously missing something somewhere in the process of converting to burning, does anyone have any ideas how to stop this im guessing it maybe a setting in tsMuxerR that im missing??
    Cheers Danny
  2. Is your mkv full frame? 1920x1080, or a cropped resolution like 1920x800?
    You have to add back the black borders for it to be fully compliant. You can re-encode with avisynth, or use uncropmkv
  3. Originally Posted by poisondeathray
    just looked in tsmuxer and yes its 1920x800 how do i go about adding the black borders in either of those programs uve mentioned i have them both.
    thanx for the quick reply btw
  4. There's instructions on the homepage
    http://multiforum.deanbg.com/viewtopic.php?f=3&t=3
  5. Originally Posted by poisondeathray
    Thank you
