Hi there
I've just released the first version of BatchShrink, a free tool to enable you to encode multiple DVDs one after another with no user interaction using DVD Shrink 3.2
You can download BatchShrink here: http://www.batchshrink.co.uk
Please use this thread to post feedback, bug reports, questions, comments etc. or email me via the website above.
Sláinte
midders
Results 1 to 23 of 23
Volunteer for https://www.computersforkids.org.uk/
If there are any problems with the website it is mirrored here: http://batchshrink.qupis.com/
Your download links don't work in IE 6. I get a invalid zip with a php source in it.
The mirror says something like file not found. http://batchshrink.qupis.com/getfile.php -
Thanks for the heads up; I'm troubleshooting it now.
Volunteer for https://www.computersforkids.org.uk/ -
I now get http://error.000webhost.com/ on main site download.
If you need some space and bandwidth for your downloads let me know. -
I've kludged a fix using my adrive account for the moment; the download link on batchsrink.co.uk should work now (fingers crossed!). Apologies for the snafu, I'll sort a more permanent fix in the next few days. Rest assured: I'm much better at C++/Win32 than I am at websites!
@Baldrick: if you could let me know about some download space, that would be great; it seems that the "free" hosting that I've opted for doesn't allow file downloading. Thanks.
midders -
OK! The download link at your main website now works.
I hardly ever rip DVD's but I'm curious so here's my first impression and comments.
Currently your app is just a Icon at the system tray that translates a user batch file
into a series of DVD Shrink command line calls (Am I right?).
FWIW...
I don't think the average user will be happy to enter two long command lines with numerous
source and destination paths in a simple text editor. Think of the typos that will be made.
You do no checking for path validity when the batch file is loaded. Currently, everything that
has gone wrong during the process has to be read afterwards from the log file you write.
Your app should startup with a gui where the user can drop the paths to the iso's and/or
VIDEO_TS folders and your app should create the batch file, not the user.
For the destination you could let the user enter a workdir where your app automatically
stores iso's and/or folders with names derived from the source names.
I would include a local help file in the zip with a description like at your website.
I would also add the ability to set the DVD Shrink settings per job. Not only once
for the whole bunch of iso's and/or video_ts folders to process.
Although the basic idea is nice and there would probably be employ for it, I think you have
to re-consider the concept to make it of interest for a wide audience.
Chris -
Originally Posted by Chris K
FWIW...
Chris
Sláinte
middersVolunteer for https://www.computersforkids.org.uk/ -
Originally Posted by midders
There are listviews that allow combos (dropdown lists), check boxes, radio buttons etc. on each line.
I don't know but assume that .Net supports that kind of listviews.
Note that this is technically spoken. It's quite a while ago I used DVD Shrink and I'm not able to say
which settings could stay global and which could be useful to set individually. -
I've been using MultiShrink for years and I'm quite happy with it. I'm not sure what advantage batchshrink brings to the table.
http://www.dvdshrink.info/chetwood/
https://www.videohelp.com/download/MultiShrink1.4.sfx.exe
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
The obvious advantage would be that batchshrink only ever has one instance of DVD Shrink running at any one time; this could prove significant when shrinking large numbers of sources. It can also be run directly from the command line, for better integration with batch processing; this would also allow remote execution without having to run remote desktop connection or similar.
I wasn't aware of MultiShrink when I started writing batchshrink, but I would probably have written it anyway; as a programmer I think it's a cleaner and more technicaly pleasing solution to the problem.
Sláinte
Version 1.01 is now available for download. This is a bugfix release and addresses the issues experienced by some users when selecting a folder for the shrink destination.
Thanks to Dewz at club.dcfreaks.com for the logfile that helped me isolate this problem.
Sláinte
By default Batchshrink selects audio streams using a substring match so that /audio="English Audio" will match "English Audio 1", "English Audio 2" etc. The exception to this is the keyword "Director" which is used to identify Director's commentary streams and exclude them from processing as standard audio streams.
There is currently no way to select between audio streams that have the same name. If you think it would be useful to be able to select audio streams by other criteria such as size, or encoding type I would be happy to consider it as a feature request.Volunteer for https://www.computersforkids.org.uk/ -
Wow, I was merely pointing out that I do not agree with your assumption that BatchShrink is a cleaner solution, not sure how you turned that into a feature request. But don't bother, I'll simply stick with MultiShrink since it already does everything I need and has been doing so for many years.
I was trying to respond reasonably to a blatantly critical post.
Batchshrink is a cleaner solution in that it only ever has one copy of DVD Shrink running at a time, and communicates with that program via the windows API as was intended by the designers of the windows interface. This may not be a problem for batches of one or two DVD's, but try processing hundreds at a time and wait for the crash...
If you were interested in helping to improve BatchShrink rather than just bashing me for its limitations you wouldn't be surprised by my earlier response. -
Same here.
Why would I be interested in improving BatchShrink when MultiShrink already does all I need? -
Which one was that then?
You're the one posting in the BatchShrink thread; if you're happy with the solution that you use, why did you bother posting in the first place?Volunteer for https://www.computersforkids.org.uk/ -
Because I simply couldn't stand your comment about Batchshrink being the cleaner solution where it's clearly lacking features the competition has been offering for years. After all, this is a discussion forum, right? But don't worry, I've gotten tired of debating already.
Hi All,
I found this tool via google - and thought it sounded really interesting.
I have lots (6tb) of movies all ripped to VOB under moviename/video_ts folders. I want to remove the menus on all of them. but keep all the audio & subtitle streams.
It seems that batchshrink would do that job perfectly.
However, the websites linked at the top of this message are dead, google cache has forgotten them too.
Does anyone have a sample batch file layout this tool requires? or a copy of the online help?
Thanks in advance
[C++] My custom FFmpeg wrapper for batch conversion between formats
By AlecTaylor in forum Video ConversionReplies: 0Last Post: 7th Jun 2011, 14:43 -
mp3 in acm wrapper?
By DarrellS in forum AudioReplies: 5Last Post: 11th Oct 2010, 21:30 -
shrink avi/divx in batch mode
By volam1 in forum EditingReplies: 1Last Post: 5th Jan 2010, 20:20 -
vfw wrapper help
By video_2010 in forum Capturing and VCRReplies: 0Last Post: 21st Jul 2009, 14:48 -
Trying to understand wrapper vs codec
By brassplyer in forum Video ConversionReplies: 1Last Post: 27th Feb 2009, 00:23
