  1. Delete the post.
  2. Delete the post.
  3. Banned
    Jul 2009
    The resolution has to be divisible by 16. After cropping you gotta resize to a valid number. And if you're getting an AVI VBR audio sync error, you can always re-encode to CBR to make it more compatible or use WAV if you don't give a damn about filesize.
  4. Delete the post.
  5. Delete the post.
