hello, how can i increase the volume of movie 2 times from the original when im starting coding?
is there any command in the avisynth script?
You're right and I apologize.
I ask again, is this MP3 or AC3 audio you're talking about? If AC3, configure the AC3Filter properly. If MP3, you can use MP3 Gain on an MP3 audio you've created yourself (or GKnot created for you earlier) and then "Just Mux" in the encoding control panel of GKnot, or mux it yourself into the final AVI using VDubMod. If you want to play with the parameters, tick the "MP3 custom Parameters (Experts)" box and play with the settings in the drop-down box of the Azid section, and perhaps add:
-boost( /b2=5 )
to boost the volume. The MP3 can easily clip (get distorted) if you're not careful. -
its mp3 audio
and i want to increase it from the beginning it start encoding not the the end that it already muxed
and if i mux it final using vdubmod it will take make another hour
i want to make it quick all in 1
thats why i asked if there is any command to put in the avisynt script before im starting muxing
10x -
Now you're not making any sense. I gave you the commands to encode the audio and make it louder. I also told you how to take an MP3 you already have and make it louder. And then you say:Originally Posted by Fire Foxer
Depending on the length of the video and your computer specs, it'll take all of about a minute or less. Just set Video to Direct Stream Copy so you don't reencode the video. In GKnot the audio isn't encoded via the AviSynth script but separately, using Azid and Lame, and then muxed into the video afterwards. Just have a look at the log to see how it's done. If you want to do it in the script (why?), then you'll have to do the whole thing manually.if i mux it final using vdubmod it will take make another hour
If you still don't understand, perhaps someone else can explain it better. -
k workin' gr8 10x
i was sure that i have to use full processing mode in order to save it after this action.
10x 8)
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Increasing Video Volume
By edlimym in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2010, 07:41 -
logo supplementation in GKnot
By Fire Foxer in forum EditingReplies: 0Last Post: 5th Aug 2009, 14:31 -
increasing volume in mp4 video
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2008, 01:05 -
increasing the volume of ac3 files
By virendra in forum AudioReplies: 4Last Post: 1st Nov 2007, 04:25
