for some reason when i take certain files now they freeze in the beginning of the movie and says that it will take the movie 51 hours to finish now i'm running an Athlon 1.3 so this seems nearly impossible does anyone know whats wrong with the file it only happens on certain ones, the movie plays fine but when trying to convert it it doesn't seem to work
or are there any other programs that i could use ?
thanks
Hello too2buff,
Try under the how to convert first. Then if any other questions should arise we can help. Also use the search function above right on this forum.
<font size=-1>[ This Message was edited by: moog on 2001-07-24 16:25:24 ]</font> -
asf are a streaming video source and sometimes if you have 2 drives this can be fixed by haveing the file otput to the next drive it is not on.
TMPGenc12a (on this site, not anymore on tmpgenc.com) has saved the day, converting ASFs that later versions won't. I think some of the problem is glitches or intentional changes to the audio encoding in the ASF. There may be a slight pop at the transition but that is it.
Da Kitty -
Use VirtualDub 1.3 (any higher version will not support ASF). If you have problems loading the ASF file, you need to use the ASF file fixer plugin for VDub. I found both Vdub 1.3 and the plugin using google.com. If you can't find them then e-mail me and I'll send you a copy of mine (about 700k). You can return the favor by viewing my posting at
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49264&forum=6
ASF to MOV or MPEG4 problems using FFMPEGX for Mac
By Maverick101 in forum ffmpegX general discussionReplies: 3Last Post: 29th Sep 2011, 13:54 -
asf to MPG conversion
By kshavo in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 05:14 -
WMV/MPG problems
By Metallian MetalGod in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2008, 22:35 -
Having problems with MPG-HD to MKV
By SpydaMan in forum Video ConversionReplies: 10Last Post: 25th Mar 2008, 22:37 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
