I am essentially trying to capture video gaming footage, Fraps does not work, the file format keeps corrupting for some reason.
I have tried, Hypercam, Wegame, Playclaw, Camstudio, Snagit, but they all do not record without being very choppy.
As for my system its decent;
Intel Corei7 920
6x1gb OCZ Platinum DDR3 1600
EVGA X58 mobo
EVGA GTX260 x 2 SLI
Western Digital 1TB x 2 Raid Striped
Resolution 1680x1050
Windows 7 RC1
Im up for ideas, the cheaper the better.
@Poisondeathray
I am not sure why Fraps does not work. Using Gspot to see if there is anything wrong with my system vs. the output file this is what i get;
Corrupt AVI header (click for details)
Details: This is an invalid AVI file due to corruption of the data in the header. This is a serious problem, and this file is not likely playable
Details: While processing chunk /RIFF:AVI, found bad length value 192 at file offset 0x00000010
That is the error I get, furthermore, When I load it into Virtual Dub it does load but before it shows the video a little box pops up and says "Reconstructing Index Block"
@ Mazinz
what particularly would be the line out? HDMI DVI ?
Getting Footage from SDHC Card from High-Def 1920x1080-60p in Best Quality?
By bmccollum in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 20th May 2010, 00:12 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
How To Capture PC Video In High Quality To DVD And Blu-Ray Disc
By blazin-j in forum Newbie / General discussionsReplies: 15Last Post: 23rd Oct 2008, 08:33 -
Capturing Video Game Footage
By CosmicOutburst in forum Newbie / General discussionsReplies: 1Last Post: 23rd Nov 2007, 18:59 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
