Ok, so I looked up of there was a code to crack the region code on my player. But when I started the steps to do it, it told me to press numbered buttons, I think it was like (3,1,5,1) but my DVD remote has no numbered buttons. Can someone help me out. Thanks.
You'll most likely need to press the number buttons; there's not really a way around that. Are you using the original remote for your DVD player?
If cameras add ten pounds, why would people want to eat them? -
Depending on the code, you might be able to enter it with a universal remote. Odd that the player has a remote with no number keys (first I've heard of anything like that
), but a look at VideoHelp's page for the player has other people mentioning it, too.
I did a quick websearch, and some of the posts I read elsewhere seem to imply you'd probably need to use one of the special maintenance/repair/manufacturer remotes (the type only available to the industry, not to home users) to make it region-free. I didn't see any that used a number code.
Edit: Is this the page on which you saw the code? https://www.videohelp.com/dvdhacks/sony-dvp-ns315/1123
There are some saying the codes/etc. do work, but I did also notice this:
...so, I don't know. I wouldn't put it past Sony to make it difficult for consumers to make the players region-free, though.Region code hack posted by Fred, October 29 2003:
Hi, ALL.
DVD-player Sony DVP-NS315 r1/r3/r2-Japan don,t have solderless upgrade
(Example: PDA, DESKTOP, IRC, CD-R and etc....) in
variant MULTIREGION, and NTSC and PAL-enable, and Macrovision OFF.
The modification of this player is done only through special
Sony-Data-service-cable and special firm software through plugs
On main-board (plug CN-103) and on IR-board (plug CN-405).
P.S.: NOTE - Besides, on main-board of this player it is necessary to install additional
Components for Pal-enable.If cameras add ten pounds, why would people want to eat them? -
I had a Sony NS305 years ago, and that needed a chip soldered inside to make it region free
Sony players are notoriously difficult to make region free and it's becoming more difficult especially to make DVD players sold in the USA and Canada become region free. I just want to warn you that there is some chance that you will never be able to make this player region free.
dvd code to multi region my sony dvp-ns39
By fcooper in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2010, 18:52 -
Region Code Assistance for Sony DVP-S530D
By Liz_Strange in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th Aug 2009, 19:07 -
region code assistance with the sony dvp-ns700h DVD PLAYER
By stressed_with_sony in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jun 2009, 01:06 -
region code assistance needed for the sony dvp ns700h
By stressed_with_sony in forum DVD RippingReplies: 0Last Post: 1st Jun 2009, 20:34 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 04:34
