The other day, I was wondering why my disk space had gotten so low, so I took a look around my computer... I have one .avi file that is 86.4GB! I looked at it's properties, and I think the reason it's so high is that its total bitrate is (OVER 9000 (Sorry, I've been wanting to use that meme for a while now)) 143392 kilobytes per second... I need to know how to make it smaller. I've already tried google, but no such luck. Any ideas?
At that size it's probably uncompressed RGB or losslessly compressed. You can compress it with any number of codecs, MPEG2, Xvid, x264. Which you use depends on your needs, what you plan to do with it.
If you have no other software, drag the file into Windows Movie Maker and export it to the smallest format consistent with your needs.
On the other hand, if it is high definition, loss-less capture of aliens landing at Roswell, NM, the demise of some infamous bad-guy, or an unpublished, discarded piece from "Thriller," you could sell the file and be a very rich honcho.
ezcap is giving extremely poor video quality, any suggestions?
By Harperlarp in forum Newbie / General discussionsReplies: 6Last Post: 26th Feb 2012, 19:46 -
Audio is extremely low
By Nintendo Fan in forum AudioReplies: 0Last Post: 26th Aug 2010, 16:43 -
After MPEG-PS conversion, beginning of the video is extremely fast
By killazys in forum Video ConversionReplies: 7Last Post: 24th Jun 2010, 01:22 -
video files are to large!!!!!!!!!!
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2008, 07:30 -
DVDauthorGUI problem with large menu
By AlecWest in forum Authoring (DVD)Replies: 3Last Post: 8th Nov 2007, 16:57
But the way you make it smaller is to re-encode it to a different format or a lower bitrate, but how depends on what it is.
