Hello!
I'm sure this question has been covered, but I didn't feel like reading through 190 pages of posts to get an answer and I'm hoping some of you could help.
How do you know which format (VCD, SVCD, XVCD) to burn? Can you tell by the file name? Is there a program that tells you what format the original file should be burned in? Can you simply tell by the name of the file?
For example, I have Clockwork Orange (XDVD-L580).avi and I want to burn the file in a format that would take full advantage of any features.
Another simpler question that I have is whether or not there is a way to determine a file's framerate other than using Windows Media Encoder and then selecting the closest value on TMPGEnc? I find this rather tedious as you sometimes have to wait a while before you get the correct frame rate as it increases slowly. Somehow, I'm worried I'm sometimes rushing the job and picking a lower framerate than I should. Any suggestions?
Thanks!
Open Virtual Dub, open file and hit file information. It will give you all the information you need.
Which format depends of what you want. There are advantages and disadvantages to XVCD, VCD and SVCD. Some DVD players have no problems playing XVCDs ancd SVCDs and others don't. If you have a Sony like me, you have edit it in TMPGenc and burn it as non-compliant VCD.
Look over on the left for format differences. For me its XVCD or SVCD.
Why do some m2ts files play on PS3 while others in the same format don't?
By chrvi in forum Video ConversionReplies: 7Last Post: 12th Mar 2012, 13:31 -
Trying to burn an mkv with subtitles, but the subtitles don't burn properly
By geramul in forum Newbie / General discussionsReplies: 15Last Post: 1st Sep 2010, 19:12 -
Burn to 16:9 format
By ozab in forum Video ConversionReplies: 11Last Post: 10th May 2009, 16:29 -
Folders don't show up in mp3 format
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 31st Dec 2007, 13:16 -
How to burn DVD files that don't fit on DVD?
By aqualung2003 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2007, 00:43
