If I author a PAL disk using Tmpgenc Authoring Works will it work in a country that is SECAM? The video specs for PAL and SECAM that I saw on the web site below look very similar...
NTSC, PAL and SECAM -- what countries use
http://www.thevideoconverter.com/info.html
Thanks!
Bob
Cant play secam on pal dvd cause they are incompatible with each other,secam uses a different color system with the picture.
SECAM is an analog TV broadcasting standard, it doesn't have any digital version. All SECAM countries use PAL digital devices like DVD players etc. and most TV receivers there have built-in PAL color decoders since VHS era.
In the digital world, there is no PAL/SECAM/NTSC. There are framesize and framerate differences.
PAL / SECAM are identical on framesize / framerate. For DVDs are the same.La Linea by Osvaldo Cavandoli
can a PAL disc work fine in a SECAM system ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2012, 04:55 -
VHS capture jumping between PAL and ME SECAM...help
By pijetro in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2009, 18:55 -
Help! - ntsc and secam versions of chapter authored pal dvds
By devdev in forum Video ConversionReplies: 3Last Post: 25th Aug 2008, 21:05 -
recording secam ?
By bugsbunny14 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st Dec 2007, 07:15 -
h.264 digital format to PAL, SECAM, NTFC formats in DirectShow ?
By manzoor505 in forum ProgrammingReplies: 1Last Post: 8th Dec 2007, 08:28
