Haven't had this problem before. Transferring some Digital8 video to DV via Firewire, I find I'm getting intermittent, brief audio dropouts. Same issue capturing both with Pinnacle Studio and WinDV. Using a brand new tape. The video image is fine. The audio dropouts occur in the same place with both Pinnacle and WinDV.
However, when I listen to the audio through the cam's headphone jack, it sounds fine and when I record the audio as analog output to Soundforge, the sound is fine. No dropouts.
This is the first time I've encounteed this. Any idea why this would be happening?
Thanks.
How's the audio if you connect the analog output of the camcorder to a regular TV and listen to it that way? This will help narrow down a FireWire capture issue vs. tape issue.
John Miller -
Originally Posted by JohnnyMalaria
Originally Posted by brassplyer
I've never had this problem.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Problem converting from digital8 PAL tape to NTSC DVD recorder
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 27th Jul 2011, 18:01 -
playing Digital8 tapes in 8mm tape backup drive
By jrh69ca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Dec 2009, 12:46 -
Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVD
By scotty123 in forum Video ConversionReplies: 0Last Post: 9th Oct 2009, 12:49 -
By scotty123 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 00:34
