i got a vcd witch the mpegs play fine, but when i try to merge the 2 files together with TMPGEnc it's saying that one of the files isn't a mpeg. what is wrong and how can i fix it.
I too have this problem with one of my Mpeg files.
The thing is, i can burn it onto a vcd in nero if i turn standard comliance off, but it is very annoying because i have to use 2 cds instead of being able to merge them in TMPGenc. :cry:
Does anyone know a program that would merge a non-standard vcd?
Or a solution so i can merge them in TMPGenc???
Thanks -
If the second half is different in anyway to the first, then the merge/split tools wont work.
You will need to use TMPGenc to convert part 1 into a VCD Mpeg, and do the same for part 2, then you can join/split them. -
Use Bitrate Viewer to find out what is different between these to files first and then fix whatever needs to be fixed in one of them
MKVToolnix merging help
By SunnyHours in forum MacReplies: 7Last Post: 2nd Dec 2010, 15:39 -
Merging mpeg
By drgt in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2010, 05:19 -
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
