It used to work fine, but lately after one of the updates, I always get the following.
Any ideas?
Maybe something got corrupted during the update? Try uninstalling then reinstalling. That update works fine here , but I'm XP
I think it must be something to do with Vista which conflicts with the latest update then. Cos I've reformated twice, fresh installed and updated. Always results in this error right after. Dang... should have stayed with XP =p oh well...
Maybe it has to do with the specific task you set it up with?
Try different conversions / codecs, different source videos, different projects, etc.. do they all get the same error message? -
I've tried all the different codecs with their AME presets with the same result.
If I run AME from a fresh install without installing any of Adobe's updates, it works fine though.
Encore CS4 screws up chapter selection on custom menu (video demo inside)
By aple in forum Authoring (DVD)Replies: 1Last Post: 31st Jul 2011, 09:53 -
Correct Presets in Premiere CS4 and AME?
By 3DHDAnaglyph in forum Authoring (Blu-ray)Replies: 13Last Post: 26th Oct 2010, 07:34 -
Twixtor for Adobe After Effects CS4
By Tahlos in forum EditingReplies: 4Last Post: 5th Oct 2010, 20:57 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
AME CS4 Audio drift but not in others?
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 15th Jun 2009, 18:27
