I notice that on many mobile phones which support H.264/MP4, only video which are within 320x240 resoution will play. When encoded at higher resolutions, video won't play with errors such as "Unsupported resolution" or audio playing without video.
This is a bit wierd.
For example the Samsung Pixon M8800 records and plays MP4 video at 720x480 with its internal camera, so we know it can play higher resolution videos. But will only play video which are encoded by software such at Handbrake if they're within 320x240 resolution. Same issue with Nokia's such as E71.
Any ideas of how we can negate this resolution limitation on mobile devices?
Maybe you can encode a video with the same characteristics as the one recorded by the internal camera, if that's the reason why (e.g. b-frames, ref frames , AVC level etc...)
You can use mediainfo, gspot, avinaptic, streameye, h264visa, etc.. to find more info on the settings you might use
If the reason why it's preventing larger resolution videos from playing is metadata (e.g. hardware encoded streams sometimes have a signature from the encoder) , you be able to hack encoded videos with at hex editor
Also you might surf the phone specific forums for workarounds/hacks that other users have come up with (e.g maybe a firmware hack) -
Same story is with the Nokia 5800XM. You are able to play videos encoded at MPEG4 SP (divx, xvid) at higher resolution (e.g. 640x360). However, if you use H264/AVC then the playable resolution is limited to QVGA (320x240). Now, we know that H264 decoding requires more processing power than divx/xvid decoding. My guess is that the manufacturers impose such limits so that the phones without HW acceleration would not choke wile trying to decode high resolution videos.
Using Handbrake, try to encode the videos at higher resolution using MPEG4 as a video codec (not the H264). This should produce a file similar to the one recorded by the phone's internal recorder.
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 01:42 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 06:14 -
Encoding iPod/mobile + PSP AVC compatible files.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 02:42 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25
