Hi,
Purchased pro version to try converting some DVDs to MPG.
After the first few minutes, the timeline does not work in VLC player or Windows Media player. It does work in Nero showtime.
If I use VOBSET instead of IFO mode, the indexes work fine.
Any ideas if this is a known issue?
[if it is of any relevance they are DVDs recorded from live TV using panasonic and pioneer DVD recorders, not commercially produced DVDs. I can attach necessary ifo files etc.]
Thanks!
	Can you try using the "recal GOP timecodes" option in the setting please? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	Hi,
 Yes - I tried that. It was the most likely solution I could think of: I noticed that feature would be available in purchased version.
 It seems to have no effect on the problem
  Windows Movie Maker 6 - Problems with playing timelineBy leegutcher in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2013, 14:16
  VOB2MPEG no VOBSET ModeBy planeo in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Mar 2011, 11:59
  DVDDecrypter IFO Mode - How do I know what cells belong to an angle?By Gatlinator in forum DVD RippingReplies: 6Last Post: 26th Dec 2010, 05:03
  preview mode in the timeline Using Sony Vegas Studio Platinum 10By JackDalton in forum EditingReplies: 5Last Post: 26th Oct 2010, 04:16
  Experiencing problems with audio in timeline, any solutions ?By Recco in forum EditingReplies: 3Last Post: 31st Dec 2009, 14:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
