had it on for a couple hours and it's up to using 225MB of memory with 1 tab open, i don't recall ever seeing v3.0 using more than 100Mb or so. only thing close on this system is thunderbird coming in using 55MB.
Results 1 to 10 of 10
Have you tried it on a new (temporary) profile, with no extensions or plugins installed, and the same site open? It could be an issue with one of the extensions or plugins you're using.
If cameras add ten pounds, why would people want to eat them? -
upgraded to 3.5.2 and it's hovering around 125 MB now instead of 225.
3.5 was a disaster for me, and I reverted to 3.0. I might venture it again now at 3.5.2, depending on what it says was fixed, or maybe wait for 3.6.
My system slowed down while searching and kept not being able to find servers on the first try. Seems to be back to normal with 3.5.2. I've never had a problem before. Just started acting up when the new Firefox came out.
Depends what the definition of the word inhale is. -
Never had a problem with 3.5.1
Although i did upgrade for the heck of it... -
Hmm!
I use that browser myself and it is working flawlessly.
From this we can deduce that the problem is a result of something local on your side. Perhaps you've installed some wild add-ons that are not yet compatible with the new version?
Shut down all add-ons and try them one by one, to see which causes the leak. Then wait until it is updated. Perhaps that is the way to avoid the problem.
Browsers are like an ocean. With every passing moment, they are different. But in the end they cover 70% of our [digital] world. - Video Ninja
*Video Ninja disappears into the darkness* -
When I had Firefox 3.5.1, my FireFTP utility would occasionally shut down saying, "insufficient system resources." Heck, I've got 2GB of RAM. Anyhoo, when I got 3.5.2, the problem magically disappeared. Perhaps that's why 3.5.2 came out so quickly after 3.5.1.
Regards,
J. Alec West
Use Firefox 3.5.2. I had a problem with 3.5.2 (and 3.5.1)-they would have trouble acquiring some sites. They would get stuck or act slowly. I made a backup of my settings using MozBackup and then uninstalled the program leaving the settings untouched (an option given when uninstalling Firefox.) Do not erase settings or they will be lost upon restart. I then installed 3.5.2 and have been off to the races since.
Don't forget to backup your new Firefox profiles after installing and checking functionality.
BP oil leak live video from well head
By redwudz in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 15:14 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
FBI arrests man over leak of Guns N' Roses songs
By Conquest10 in forum Off topicReplies: 22Last Post: 28th Aug 2008, 23:17 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 07:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 15:31
