In a public hotspot I see two networks, both without encryption. I can connect with my laptop to both of them and I receive the local IP address and everything looks fine. However, with one network I can surf, while the other one gives me an error message in IE "Network Server not found". Is this the MAC filter blocking me?
What does it matter? Since you are able to surf with one, you don't need the other.
Bottom line is that you have no control over someone else's network, so we wouldn't really have a clue as to why you're blocked.
If you know who owns the network, ask them. -
Well, the reason is that the network that doesn't allow me the surfing give the strongest signal. The one I'm using now has a very poor signal, so I have to hold my laptop only in a certain position to get the data running.
I curious of the reason, why one can't use a browser, if the IP address, Gateway IP, subnet mask are allocated and the network uses no encryption.
Like you said, mac filter.
or, they may have a terminal-type login (rather than encryption keys). I've seen it used at hotels.
Probably a dozen other reasons (a wireless router with no internet connection, maybe?)
mainconcept mp4 demultiplexer connection issue
By sder33 in forum Video ConversionReplies: 1Last Post: 12th Sep 2011, 06:50 -
WIFI AC and WIFI AD coming in the next few years
By yoda313 in forum ComputerReplies: 0Last Post: 31st May 2011, 10:01 -
Odd connection issue with Comcast.
By Poppa_Meth in forum ComputerReplies: 16Last Post: 7th Oct 2010, 06:53 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47 -
Vista wireless connection issue.
By Poppa_Meth in forum ComputerReplies: 10Last Post: 26th Aug 2007, 13:23
