Hi!!!!!
I have a sr10 pal (25fps) videocamera. It creates mts files. I copy them to my computer hard disk. After that, I use TsMuxeR GUI 1.10.6 to create one file. When creating it, tsMuxeR says:
SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
Decoding H264 stream (track 1): Profile: High@4.0 Resolution: 1920:1080i Frame rate: 25
H.264 stream does not contain fps field. Muxing fps=25
B-pyramid level 2 detected. Shift DTS to 3 frames
Decoding AC3 stream (track 2): Bitrate: 448Kbps Sample Rate: 48KHz Channels: 6
Decoding PGS stream (track 3): Resolution: 1920:1080 Frame rate: 25
Processed 45162 video frames
Creation of AVCHD playlist
Creation of AVCHD stream info and seek index
Mux successful complete.
Muxing time: 7 min 52 sec
In the third line it says "H.264 stream does not contain fps field. Muxing fps=25". When I play the file created, the sound is not synchronized. Can it be because of that third line? What can I do?
