    Aug 2009
    Italy
    Sorry if I wrote here but i don't understand if the bugs should be reported here or in some other place, please forgive me in case I 'm wrong.
    FROM the last releases of BD Builder (the old beta expired) I always receive the following error:
    (I tryed also the last release 0.26.02 with the same result)
    [13.23.33] BD Rebuilder v0.25.04 (beta)
    - Source: WANTED_G51
    - Input BD size: 43,52 GB
    - Approximate total content: [03:58:27.192]
    - Target BD size: 22,46 GB
    [13.23.36] PHASE ONE, Encoding
    - [13.23.36] Extracting A/V streams [VID_00047]
    - [13.23.41] Reencoding: VID_00047 (1 of 29)
    - Error in attempt to multiplex: MUX_00047.meta
    - Can't create file H:\BDREMUX\WORKFILES\TMP\BDMV\STREAM\00000.m2ts
    [13.25.12] - Failed to build structure, aborted
    Hi tryed with more than one movies.
    Any Idea?
    Regards
    \Gianni
    25.04 is not the latest. 26.02 is. Or maybe the log reports wrong.
  3. Have you successfully rebuilt any discs?
    Have you installed Avisynth, ffdshow and haali splitter?
    Pull! Bang! Darn!
    Aug 2009
    Italy
    *****UPDATING*******
    I update the ffshow,haali media slplitteer,avsinc alll with the last release.
    After I reboot the pc and now all seems works fine.
    Probably I had some hanging in the system...
    Thanks for the helps all try to give me.
    Regards
    \Gianni
    Feb 2009
    Any Idea?
    Regards
    \Gianni
    Was this reencoding attempt from iso or original disc?
    ocgw
    peace
    i7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
    https://forum.videohelp.com/topic368691.html
    Aug 2009
    Italy
    From ripping on HD done with anydvdHD.
    Now the BD tool works fine.
