I am looking at this option. http://www.hauppauge.com/site/products/data_hdpvr.html however I need some questions answered.
1. Would I be able to use this to capture video to my PC without physical capture card/software?
2. With the IR channel changer will it change the channel I sch on my PC to capture and allow me to watch another show on my actually TV set with my DVR having 2 tuners.
If the answer to number 2 is no, then what might be other options for me?
__________________
DirecTV
5 Multi LNB Dish
1. DVR - R15-300 Bed Room
2. HD-DVR - HR22-100 Software 0x312 on HD DVR
Package
CHOICE XTRA™ + HD DVR — Locals Included
PC Specs
System Model Dimension 4600i
System Type X86-based PC
Processor Intel(R) Pentium(R) 4 CPU 2.80GHz, 2793 Mhz, 1 Core(s), 1 Logical Processor(s)
4GB's of ram
BIOS Version/Date Dell Computer Corporation A12, 8/26/2004
SMBIOS Version 2.3
I have that unit, it's been quite satisfactory.
1) It comes with Arcsoft TotalMedia Extreme. Capturing is as simple as firing it up, hit Capture Module, set bitrate, duration, and press "Capture". Nothing could be simpler. The included software can also do basic editing (very basic), and authoring to AVCHD disc. The result plays fine in my Sony BDP-S360. If that option is appealing, be aware that not all Blu-Ray players support AVCHD. AFAIK, all current Sony, Panasonic, and LG players do. Samsung is evidently withdrawing support, earlier players were okay, current ones are hit-and-miss. AVCHD support will be in the specs for the particular player.
The included Arcsoft DigitalTheater will play BD, AVCHD, and what have you. And it's a hell of a sight better than PowerDVD.
2) I couldn't get the damn remote to work. With my last capture device (Winfast HDTVCinema), I never could get that remote to work either. :P I would suggest getting a decent remote that can do the job, like an iMon.
IIRC, the included IRBlaster *CAN'T* integrate with the Arcsoft software anyway, although supposedly it can control "third party" software. So why it's included is beyond me.
Anybody want to buy mine? Cheap?
As to the last part, I dunno, I just have an HD cable box.
Good luck.
Pull! Bang! Darn! -
So, no one can answer this With the IR channel changer will it change the channel I sch on my PC to capture and allow me to watch another show on my actually TV set with my DVR having 2 tuners.Originally Posted by fritzi93
If the answer to number 2 is no, then what might be other options for me? -
1. Yes
2. No ...Unless you are watching a ClearQAM channel off the TV tuner. The HD-PVR takes the monitor feed from the cable DVR.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Does your DVR have two component outputs? Without a second component output the HD PVR will only be able to record what you are watching anyway.Originally Posted by wcwman18
Leave the DVR on and tuned to the channel you want to record. Obviously, that will only work for recordings from one channel.Originally Posted by wcwman18 -
A second HD cable box.Originally Posted by wcwman18Recommends: Kiva.org - Loans that change lives.
SCART Capture - Cable and S-Video Question
By hech54 in forum Capturing and VCRReplies: 1Last Post: 19th Jan 2012, 09:00 -
Video capture quality question
By fattyriver in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2010, 14:10 -
Simple question about video capture from ps3
By adamsbomb in forum Newbie / General discussionsReplies: 0Last Post: 11th Mar 2010, 00:48 -
Video Capture software question
By kgingreen in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2010, 13:07 -
Question about 2nd Hard drive for Video Capture??
By VEBouto in forum Capturing and VCRReplies: 8Last Post: 21st Nov 2009, 06:46
