Hi
Please forgive my possible stupidity but I need some help with iMovie.
I have just imported my first VHS tape using iMovie.
I have found the .dv file and just in the process of loading this back into iMovie...
Is this what I should be doing ?
Or is there some process I should follow when converting VHS tapes into iMovie ? If there is could somebody
please point me in the direction of maybe an idiots guide to do doing this ?
Sorry just learning about all this.
You are doing things properly. What do you plan to do with the video once it's loaded into iMovie? You might find iMovieHD an easier app to deal with (since your footage is already in DV). PM me if you'd like the link to the app. Apple used to provide the link for iMovie users who hated the new version of the app (I count myself among them) but, although you may continue to use it, Apple doesn't tell you where to get it any more.
I'm pretty sure this works with the ADVC-55. iMovie can see that device and capture directly into iMovie so it is all done in one step. Connect everything before launching iMovie and then choose Import from Camera...Originally Posted by wahsac
iMovie does recognize it but it did not go straight into iMovie, but that may have been my fault as i had left an old event in thereOriginally Posted by Frobozz
From Vegas to iMovie - Does the version of iMovie matter?
By and in forum EditingReplies: 4Last Post: 11th Dec 2011, 21:05 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Using iMovie
By bobl in forum MacReplies: 2Last Post: 2nd May 2008, 21:08 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
Need advice on converting MOD (mpeg2) files to usable format for iMovie
By InsanelyOne in forum MacReplies: 3Last Post: 9th Sep 2007, 16:23
