Hello.
I'd like to replace audio tracks in a DVD. The reason for this is that I have a couple of films in two versions: One in Spanish in letterbox format and one in English in widescreen format. What I want to get is a widescreen version with the audio in Spanish.
I've read some posts in the forum, but I find them too difficult for me, since they deal with menus and other stuff. I just want to deal with the main movie.
My plan is to simplify things by using DVDShrink to get the main movie out from both DVDs, without menus (probably removing ALL audio from the widescreen version) leaving just the .ifo and .vob files and compressing it to a size that will leave me enough space to add the Spanish audio from the other DVD.
To sum up, I'd like some help on the following:
1. How to extract the AC3 audio from the Spanish DVD.
2. How to add this audio file to the widescreen .ifo and .vob files leave them ready to burn on disc.
I don't think I'll have syncing problems - but if I came across them, is there a way to fix them? (Even with trial and eror).
Thanks.
Do you know if both sources are the same video format(PAL or NTSC)?
1.Rip with DVDDecrypter in IFO mode and set file splitting to none.
2.Use VobEdit to demux.
3.Use DVDLab Pro or TDA to author. -
It's just as easy to keep the menus, if that's what you really want. Put the entire DVD on the hard drive using DVD Decrypter in File Mode. Demux the movie using PGCDemux. Replace the audio when reauthoring the movie with Muxman. Replace the movie with the new audio back into the original DVD using the "Replace" button of VobBlanker.
Thank you very much, Moviegeek.
BTW - Cool pic of Eastwood... I'm a big fan of him, especially of his work as a film director.
Easy way to extract (demux) audio tracks from Blu-ray folder?
By ricsee in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2011, 12:12 -
Replace audio on a DVD
By danielmak in forum MacReplies: 7Last Post: 31st Oct 2010, 23:40 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
replace audio track in retail DVD
By foolosophy in forum AudioReplies: 7Last Post: 2nd Aug 2008, 19:04 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 13:56
