I have a Panasonic A120 DVD. After trial and error, I found that the Memorex CD-RW (green box) worked the best for playing VCDs in it. I had a success rate of 90%.
However, the last 2 batches of this brand are not working anymore. I've since tried Imation and Memorex (Music CD white box). These were the only other CD-RW available at Best Buy.
Anyone have any insite?
Rick
well umm dont know much about this but what i use for my sony dvp is princo cdr and if u go to the sony website or look into the manual it will say that the dvp models do not work with cdr and barly work with cdrw
thats how good princo is
u can buy it from circuit city under a digitalmedia label cdr for pc it might work for u or if u wanted a cdrw so u could reuse it then....no idea
also i think memorex changed their cdrws because a lot of peeps have complained that it no longer works on their systems
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 13:37
I have found that CompUsa CDRW 4X have worked very well for me....JohnS
