    Aug 2009
    Australia
    I've converted my free report into a powerpoint to upload to my blog and distribute to video sharing sites but the quality of the text is too poor to use. So I now have some questions and need a bit of help.
    Does anyone have any tips on improving the quality of text in videos?
    What is the best system to use for powerpoint to video... i've tried moviemaker and memoriesonweb and both times i've ended up with poor quality
    Perhaps it's just the format i'm saving in ... what's best to use?
    Any help greatly appreciated
  2. Why not just upload the .ppt to a free file hosting site? or is this a timed presentation with audio as well?
    In terms of best quality/compression ratio, that would be h.264 video, aac audio
    You are probably limited by the video sharing site, most of them re-encode with poor quality, so even if you upload a masterpiece, it ends up looking like crap. Maybe you can start by providing more info on what format you are uploading with , and what site you are uploading to
