I know such devices exist for desktops as PCI-E cards, but are there any that I can use on a laptop?
	You can check out the hauppauge hd pvr 1212.
 It does component input capturing via usb. It does high def widescreen recording to m2ts files (now avaialble with mp4 container recording).
 Plus it can record audio via fiber optic input in full 5.1 dolby digital.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	thanks, but this is more a standalone device, id prefer to capture with my computer so I can have full control over the process, plus its pretty expensive, $250.
	Well price aside it is not standalone. It is controlled by your pc. It has normal capture software. And it does exactly what your asking for.
 I don't know of any other external unit that can record from component sources. There may be by now. You will have to keep looking if this isn't in your price range.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	Well, I don't need 720p capture.......... YET.
 I can get a Black Magic Intensity Pro for a new desktop buildwhen the time comes, although I won't lie that this device is very tempting as well.
 But right now I just wanted something small and cheap that can do 480p, didn't need 720 or 1080.
	Every single one of those can only do composite or composite and svideo, not component, meaning they can't do 480p.Originally Posted by BaronJT
 And half of them got fairly low reviews
	The Blackmagic Video Recorder does SD component to h.264. They aren't clear whether 59.94fps 480p is supported.
 Call them.
 http://www.blackmagic-design.com/products/videorecorder/
 I hate when specs aren't specific. Since they don't say progressive, I have to assume it is 480i/576i interlace only.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  Reliable USB capture devices?By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 20:32
  PowerDirector 8 doesn't work with USB capture devicesBy chris18 in forum Capturing and VCRReplies: 0Last Post: 10th Feb 2010, 07:28
  USB capture devices vs USB tuner devices...... which are better for recording?By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 16:04
  PCI and USB capture devices to AVOID? Go straight to WME...By tedbragg in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 11:02
  Need USB/Firewire 480p capture over componentBy Try4ce in forum Capturing and VCRReplies: 2Last Post: 3rd Jan 2008, 16:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
