Has anyone got the DVD-RWs to work in Philips DVD 711 player?
I have no luck![]()
Please share you experience.
Results 1 to 13 of 13
I went to buy 722 and now it works. Please don't tell me a solution to 711 anymore or I'll be pissed off..
okay the solution is that to buy the 722, the 711 doesn't support dvdrw.
I know I'm a smart %#@$, but its a living.
Yes! Philips 711 supports DVD-RW and DVD-R
I'll repost what I posted on Doom9's IfoEdit forum:
I was having trouble with "The One", as the movie (widescreen only) was 3.03 gigs. After reading a post about my player I added a 1.13 gig file full of nulls as padding to the root directory of the DVD. This brought the total up to 4.2 gigs and both the Pioneer DVD-RW I initially made for testing and the three dollar bargain DVD both play wonderfully. For you Philips fans out there here is what I did/used:
Ripped ALL files with DVDDecypter 3.0.09
Followed Doom9's Layer stripping guide at: http://www.doom9.org/mpg/ifoedit-advanced.htm
Removed id's 2-5 from video_ts.ifo
Deleted all VOB's aside from:
VIDEO_TS.IFO
VIDEO_TS.BUP
VIDEO_TS.VOB
VIDEO_01_0.BUP
VIDEO_01_0.IFO
VIDEO_01_0.VOB
VIDEO_01_1.VOB
VIDEO_01_2.VOB
VIDEO_01_3.VOB
I made a little app to create a blank file, no biggie, three api calls and you're done. Maybe Derrow could add an option for padding files *hint*
Burned the DVD with Nero 5.5.7.8 and Pioneer dvr-a03 with 1.65 firmware and the following structure:
root dir - pad.dat
VIDEO_TS - all other files
AUDIO_TS - empty
Thanks much Derrow and Doom9.
this DVD-RW isue is gonna make me go crazy.
here is what I found out.
Philips DVD 711 plays DVD-RW but has to be revision 002 not 001.
001 doesn't read it, it tries for about a minute and spits the RW out.
no problem whatsoever with 002 revision.
anybody with revision 001 succesfull ???? -
Finally got my Pioneer A04 a few days ago. Tried Ulead DMF and Sonic DVDit to author/burn Verbatim and Pioneer DVD-RW. My Philips 711 (no idea of revision number?) could play the Pioneer disc but not Verbatim. Will try other brands later and update.
Originally Posted by jackosh
There should be a sticker on the back of your player with
number on it.
I asked folks a philips repair center and they said it is not
revision number but what region it was ment to be used in.
Could you please check your:
firmware version:
P code:
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
DVD Disk Lock??? i locked my dvd player i need password! (PHILIPS DVP3520)
By kamzo91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Aug 2010, 15:14 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Is it possible to have G.711 audio in an H.264/mp4?
By Jean777 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2010, 17:53 -
Repairing the DVD Drive -- Philips PET 1000 Portable DVD Player
By ORSteve in forum Portable VideoReplies: 1Last Post: 13th Aug 2007, 13:45
