I got this program and I am liking it so far, I didn't have enough RAM initially so I bumped it up to 3GB's. However I am still experiencing some problems such as:
Crashes during simulation occasionally(possibly due to Ultra Mon running???)
Output DVD's ocassionally have jumps (even with content <4.7GB).
Any ideas on why the problems?
STATS:
Burning AVI files
Verbatim DVD-R
20X Sony NEC Optiarc Drive
ATI Radeon X300/X550/X1050 Series
K-Lite Codec Pack
Running Dual monitors during authoring and encoding (UltraMon)
Burning at 4X speed
Microsfot Windows XP
Professional
Version 2002
Service Pack 3
Intel Pentium D CPU 3.00 Ghz
2.99 Ghz, 3.0 GB RAM
NOTES:
-Software website says requirements are Pentium 4 2.4 GHz (HT Technology) or better. Not sure if this is the problem (thought D was better).
-Also I didn't make any adjustments to the BIOS or anything after installing new RAM, that could be it to (should I make adjustments after new RAM?).
-I don't multitask during encoding, I start it and don't touch the computer till its done burning.
PS
What are the best settings for this program? I have heard I should:
CPU Multithread settings: Use multi thread for filtering=OFF, Use File Caching=ON, Prefetch cache settings while encoding, both video and audio=OFF.
DVD Video Settings: Video Encoder Advanced Settings-Motion Search Position=Highest with error correction, Output bit stream for editing=OFF, Detect Scene Change=ON
MPEG Settings: Encoder Multithread settings All=OFF
Results 1 to 1 of 1
My TMPGEnc Authoring Works 4 in window 7
By sleung in forum Newbie / General discussionsReplies: 0Last Post: 11th Sep 2011, 19:54 -
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 02:25 -
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 01:59 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 21:15
