I execute the following command line for ffmpeg.exe
-i C:\Beema\video-source\DO_U_BEEMA176x144short.avi
-i C:\Beema\temp\9016730-51056331-stitcheds.avi
-i C:\Beema\video-source\GOTTA_BEEMA176x144short.avi
-y -ac 1 -r 24 -b 25K
C:\Beema\video-out\9a062fb6-d448-48fe-b006-a85d51adf8a1.mpg
The output file in video-out ends up having a single copy of DO_U_BEEMA. I do not understand why ffmpeg is not concatenating.
Any help is dramatically appreciated,
Peter Olson
You cannot concatenate with FFmpeg.
Use a small Avisynth script like;
AVISource("C:\Beema\video-source\DO_U_BEEMA176x144short.avi ") + \
AVISource("C:\Beema\temp\9016730-51056331-stitcheds.avi ") + \
AVISource("C:\Beema\video-source\GOTTA_BEEMA176x144short.avi ")
Then use that as source for FFmpeg. -
Thanks. I thought that was true, but doing some googling led me to believe that you could concatenate.
Appreciate the feed back.Peter Olson -
Yeah found this, but that's still not FFmpeg that does it.Originally Posted by peterdolson
It's joining the files with a dos command and FFmpeg gets still only one single file.You can also use ffmpeg to concatenate multiple videos into one long video. Start by transcoding all the individual videos into MPEG format, all with exactly the same bit rates, codecs, image resolutions, frame rates etc. Mistakes can be avoided by using one of ffmpeg's predefined targets such as ntsc-dvd or pal-dvd. Once that's done, simply string the resulting .mpg files together using "cat" and redirect the output to another .mpg file. Now, the timestamps inside the resulting, big .mpg file are all going to be messed up, so you'll have to process the big .mpg file with ffmpeg again. This will have the effect of putting the timestamps right.
You probably need to add "-fflags genpts" to the command line to get the time stamps right.
I would trust on Avisynth much more to do the job decently. If you found other approaches with FFmpeg, please let me know.
WinDV used to work fine ! But not working now
By vatsyk in forum Capturing and VCRReplies: 2Last Post: 8th Mar 2010, 06:43 -
ffmpeg fine concatenation does not work
By peterdolson in forum Newbie / General discussionsReplies: 1Last Post: 31st Jul 2009, 15:56 -
concatenation problem with MP4Box
By kaymyst in forum Video ConversionReplies: 0Last Post: 15th Dec 2008, 07:28 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Prototype HD DVD-R Writer seems to work fine.
By videopoo in forum Authoring (DVD)Replies: 3Last Post: 31st Dec 2007, 18:52
