    Mar 2009
    Is it possible to add multiple cut to a project I have loaded into MeGUI? I have some TV captures I would like to edit the commercials out of and I would like to avoid using MPEG2VCR. If there is another program out there that will take the cuts out and leave the resolution 720x480 please let me know.
  2. You can use the avs cutter in megui's tools menu. If you script doesn't specify both audio & video, you need to use a cuts file for the audio
    Or you can cut the MPEG2 beforehand with something like videoredo
    Mar 2009
    I just do the video in MeGui. I edit the audio I need for my stuff in VDM. The avs cutter will allow my script to have cuts in 4 seperate spots? I will get the cuts that I need in VDM.
  4. Originally Posted by MegaTonTerror
    Yep, it just uses avisynth's trim()
    You specify the frame#'s
    Mar 2009
    Fantastic. That will save me from going to Huffy then, Thanks
