i have got some mp3 of which the codec in mp3 tag says is mpeg2 layer 3. i want them to be changed to mpeg1 layer 3 the standard form. how can i achive it? thanks
AFAIK, not possible without re-encoding (which implies yet another loss of quality).Originally Posted by sumeshkri
MPEG-2 layer 3 means: samplerate = 16/22.05/24 kHz,
bitrate = 8/16/24/32/40/48/56/64/80/96/112/128/144/160 kbps. -
next choice would be - dBpoweramp Music Converter - you'll have to also install the optional mp2 codec, available on their site.
Are you sure the tag isn't just being dumb?
(Or that the audio was labeled by somebody that doesn't know what MP3 is?)Want my help? Ask here! (not via PM!)
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29
