Can anyone lend a hand with this very odd problem?
I upgraded to IE 8 a while back. Windows update, etc works fine. About three weeks ago I went to check for updates (I do this myself, not automatically) and IE gives me a windows saying that
"thank you for your interest but in order to get webupdates from this site you must be running IE 5 or greater."
It then gives me the link to DL IE ver 8. (microsoft's site)
my about file still shows IE 8 and what version I am running.
For arguments sake I had IE8 re-install all was fine and did some upgrades, now a few weeks later once again this problem comes up
anyone have any idea what in the world is going on??
I do use and prefer firefox, but since IE is still on here I do keep it upgraded as well
UPDATE: boy that was fast!! It seems Norton 2009 anti virus was blocking something. I turned it off and once I did that IE8 was working fine.
so take note if you use Norton antivirus 2009 and have the same issue as I did
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 14:57 -
Microsoft Update Won't Download??
By HotDamn! in forum ComputerReplies: 6Last Post: 31st Mar 2010, 11:13 -
Microsoft: Free and open source software violates 235 Microsoft patents
By rkr1958 in forum ComputerReplies: 32Last Post: 11th Jun 2007, 23:36
