I can't remember where it was originally located, but I found an old log in "my documents", that I had saved from before, I am pretty sure that I did not change the name, it is named vlc-log.txt, just do a system search for it, hopefully it will show up, sorry I can't be of any more help.
i've been searching for a file that ended in .log not .txt so maybe i'll be able to find it now.
or maybe not. searched the entire c: drive and no go. maybe it was in temp folder, but i empty them everyday. next time i'll look there.
thx
Where is the VLC 'Log'?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2010, 11:28 -
x264 log file
By txporter in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 15:40 -
ffmpeg log file is empty...
By sunburnt in forum LinuxReplies: 0Last Post: 24th Nov 2009, 18:39 -
FAVC log file
By marioval in forum Authoring (DVD)Replies: 3Last Post: 31st Jan 2008, 06:17 -
divxmuxgui would write subtitles to play on wmp but not on vlc
By greendesert in forum SubtitleReplies: 1Last Post: 28th Sep 2007, 04:03
