Sorry if this has been posted but I've looked everywhere and no one is quite answering exactly what I need.
With my movie collection, I simply rip the full DVD to my computer which leaves me wth a VIDEO_TS folder and a AUDIO_TS folder. Then use VLC and open them like a disc from my disk drive.
But, I'd like to put them on my external hard drive, connect that to my Xbox 360 and play through my home theater. Problem is, my Xbox won't play it the way it is.
I don't want to compres the video at all as file size is not an issue and also most of the DVDs I want to watch are TV shows and I hate tagging.
Is there a way to make it so when I browse my videos on my Xbox and play it, it will read the file just like a disc with the full menus and all. For example, selecting Entourage, Season 1, Disc 1 will bring up the full menu with the episode selection.
All I've been able to find is this: "Set DVD Decrypter to rip the movie as one big vob file rather than the default split files. Then rename the single movie file from .vob to .mpg and it should play fine over the 360.
Will this work?
Thanks in advance for your help!
It will work but with no menus and such. I don't think you will find a method to keep the menus.
Also you can't use ntfs drives on the 360. It must be either fat 32 or mac hfs format.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Good to know! I was about to reformat my drive into NTFS so I could compress the videos without much compression leaving me with a file possibly above 4 GB.
If I decide to convert them, what do you think would be the best format to keep quality high with file size being negligible?
Thanks.
Tearing my hair out trying to convert HD movies for Xbox 360
By gers1978 in forum Video ConversionReplies: 5Last Post: 4th Oct 2011, 07:30 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
PS3/XBox 360 not streaming movies w/ 5.1 surround sound
By spicoli0525 in forum AudioReplies: 1Last Post: 3rd Mar 2010, 05:49 -
Sony Blocks Movies from Xbox 360
By MOVIEGEEK in forum Latest Video NewsReplies: 7Last Post: 4th Dec 2008, 11:35 -
backing up and playing through xbox 360 on my tv
By Dalspaugh in forum Authoring (Blu-ray)Replies: 1Last Post: 5th Nov 2008, 15:45
