    Jul 2009
    Hi
    I purchased a Canopus ADVC 55 which has a 6 pin Firewire connector, my Mac Pro has the square type which I
    think is 9 pin.
    So how do I connect the ADVC 55 to my Mac Pro.
    USA
    Yes, the extra two wires are for power. If your PC only has a four pin connector, you would need a separate power supply for the ADVC.
    The correct PS for it is a ADVC-PSU5V Power Supply. If you use a non-Canopus PS, it voids the warranty. They are about $40US, but look around Amazon UK and they may have them for a reasonable price.
    Jul 2009
    Thinking on I believe the Mac Pro to be 9 pin firewire...
  4. Mod Neophyte redwudz's Avatar
    USA
    You might have some difficulty finding a 9 pin to 6 pin FireWire cable. But here's the FireWire pinouts: http://pinouts.ru/Slots/ieee1394_pinout.shtml
    Jul 2009
    I assume one of these would work and if so would I still need the power adapter ?
    http://www.euronetwork.co.uk/acatalog/Firewire_Cables_IEEE_1394B_9_pin_B_-_6_pin_14-1082.html
  6. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Your Mac Pro has FW 800. THe ADVC has FW 400.
    This Cable will do the trick, I have used it and it is great.
    Amazon.com 9pin to 6pin fw cable
    Yes you will need Power. A retail ADVC should have come with the
    PowerBrick, did you not buy this retail?
    Direct Buy from GrassValley.com
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Jul 2009
    Thanks for the reply.
    The Canopus ADVC 55 was purchased from http://www.smartdv.co.uk/
    The ADVC 55 can get its power via the 6 pin Firewire port, if you only have a 4 pin Firewire then you need to buy the optional Power
    adapter which comes with a 6 pin to 4 pin fire wire cable. So it seems that I do not need the power adapter after all, found this out after posting.
