I am looking for a reliable avi to dvd burner as I want to burn a few videos so they can work on my dvd player.
suggestions?
There are many, of varying quality and ease of use. Generally speaking, the simple to use ones make concessions to quality. If that's ok, here's one recommendation (others here will undoubtedly chime in soon with their own ideas): Quick Media Converter will convert from a great many formats into DVD (among many others). It is very easy to use, and it's free. Then burn the resulting file with your favorite burning program (ImgBurn is superb, and it's also free).
QMC defaults to "easy" settings for people who just want it done. It does, however, also have an expert mode for those who want to tweak things to suit their taste. Give it a shot and see if you like it. If you don't, the manufacturer will gladly refund you twice what you paid for it. -
I like AVStoDVD or DVD Flick, but they will take a little extra effort on your part to set up. The simplest quality solution is not free, but is cheap - ConvertXtoDVD. Handles most formats, has a reasonable amount of options, and is very reliable.
Read my blog here.
Best FREE (not a trial) EASY software to convert UTube movies onto a DVD???
By jacknscoob in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2012, 01:37 -
Need a Program to convert avi/mkv/ogm to dvd that is free for winxp
By animefanx in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2009, 03:22 -
Good, easy avi editing program
By arnie22112000 in forum EditingReplies: 0Last Post: 2nd Aug 2009, 16:18 -
DVD Motion Menu Buttons (Free & Easy)
By ImaWeTodd in forum User guidesReplies: 31Last Post: 28th Jan 2008, 16:12 -
Free DvD burining program
By lglrgl in forum Authoring (DVD)Replies: 2Last Post: 18th Aug 2007, 21:42
