Hi,
I have an MP4 video with AAC audio at constant bit rate.
I can extract the audio track in raw audio.aac file with ffmpeg or avidemux
ffmpeg -i "input.mp4" -acodec copy audio.aac
Then I need to use that audio track into a different video.
MP4Box is not working: seems the AAC file is missing the bitrate (128K) and produces the following error
[17:03:50] : Error - 2 input names specified, please check usage
Avidemux is not able to import .aac file
What is the proper workflow to extract the audio without re-encoding (do I need a container for the raw aac?) and use it with a different video into an MP4 container?
Any suggestion?
Thank you!!!
CLI to mux/merge MP4 video and AAC audio?
By RogerTango in forum Video ConversionReplies: 8Last Post: 13th May 2013, 15:43 -
mux h264/aac flv into h264/aac mkv
By Pitorasilo in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2011, 09:36 -
Need help with AAC audio track
By mkr10001 in forum AudioReplies: 5Last Post: 16th Jun 2010, 11:06 -
How to mux AAC and Xvid?
By dzsoul in forum Video ConversionReplies: 7Last Post: 29th Mar 2009, 00:51 -
Easy way to mux new audio track into DVD?
By MrMoody in forum DVD RippingReplies: 2Last Post: 2nd May 2008, 20:28
