Hi all,
Thought I'd share with you something I only found out recently. I had been using my old Sony DCR-PC5 camcorder for years, in a helmet camera setup to film my ATV rides. Recently I had an "incident" in which the PC5 did not survive... So I went shopping for a new camcorder to use with my bullet camera, but it appears that many camcorders nowadays do not have support for a LANC remote control or even A/V IN connections. That really blows because I need both and so do a lot of people who use their camcorders for helmet cams. After much surfing and reading a lot of forum posts, I found out that the new Sony camcorder actually pretty much all have native support for LANC and A/V IN but just don't have the required jacks installed on them for some reaso (probably to save a couple bucks manufacturing!)...
But then I found a company who makes an adapter cable which connects to the new Sony camcorders via the weird D-shaped connector, and lets you hook up a LANC remote AND gives you RCA jacks to hook up the external camera and mic. It's not cheap $50 but works like a charm http://www.prolanc.com I found mine on eBay and saved a few bucks. I use it with my brand new HDRCX12 and it works as advertized. I already owned the LANC remote but otherwise you have to get one of these too but they're fairly cheap. If you don't want to use it with a helmet cam, the cable will also control the camcorder directly in camera mode, pretty neat!
Results 1 to 1 of 1
Build my own LANC extension cable??
By Cazz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th May 2011, 23:06 -
Sony camcorders w/ LANC connector
By kortmann in forum Newbie / General discussionsReplies: 14Last Post: 7th Apr 2011, 01:11 -
Failing elderly Sony 8mm camcorders
By pgoelz in forum Capturing and VCRReplies: 5Last Post: 29th Mar 2010, 20:44 -
Sony Digital8 Camcorders
By k2skier in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2009, 14:10 -
Newbie Question about Sony Vegas 8 Platinum & Flash or HDD Camcorders
By rico_ita in forum EditingReplies: 10Last Post: 17th Nov 2007, 15:05
