hi,
I'm looking for a video tool for mac os x(free if possible) that gives me the possibility to crop 4:3 or 16:9 without unscaling the image that would just add black bars to the video and keep the aspect ratio.
thing is i wanna burn a video onto dvd but when i use ffmpegx and put it 16:9 720x480 to create a video_ts it screws up the scaling and doesnt crop, it enlages the image to fit the frame.
it could be a tool in a more complete video program or a simple application that does only that.
i googled and i read many forums but i haven't found a way to do this
-Frank
Macbook pro 2.4 Ghz/4Go Ram/ OSX 10.5.7
You might get better help in the ffmpegx subforum. If you post there, someone would inevitably ask you to give more details, such as source and target file parameters, and what settings you selected. Ffmpegx has many, many options, and it sometimes defaults to choices you may not like. But you can generally override them and make it do your bidding. Without knowing more about what you did, you may not have clicked the appropriate choices (e.g., letterboxing) to get the correct result. Or it could be a bug in the code. Hard to tell at this point.Originally Posted by francoislebel
I'll move you to our Mac forum and you may be able to get more answers there.
And welcome to our forums.
Submerge should do this. I use it and it will add the black bars necessary to pad "black" above and below the exiting video. I then can export as I need.
I do not do DVDs any more so I can't guarantee results. However, the app is free to download and test and, IIRC, only cost $10 once I found it would do what I needed. -
submerge is only good for playstation 3, xbox apple tv ipod and iphone
it's of no use for dvd players. unless theres a work around i dont see on their website. -
If you use the "Force X:X Aspect Ratio" commands, it will add a black background of the appropriate size (based upon which of the commands you choose). This may be saved as a QT Movie and then dropped into whatever you use to encode/author. You don't actually have to "export" to any of the devices you mentioned.
Crop/Remove black bars without re-encoding?
By agent154 in forum Blu-ray RippingReplies: 55Last Post: 22nd Aug 2015, 20:06 -
VirtualDub + Crop Filter adds a black border in right corner of video?
By CactusMan in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2010, 08:24 -
How to add black bars to Crop video without changing dimensions
By DavidCasillas in forum MacReplies: 6Last Post: 20th Sep 2009, 07:37 -
how can i crop out black bars to enlarge video for youtube
By ted demen in forum Newbie / General discussionsReplies: 10Last Post: 27th Mar 2009, 23:10 -
Crop black bars from .mkv files without recoding
By Gillie in forum Video ConversionReplies: 5Last Post: 14th Oct 2008, 17:04
