Hi all - I have a LaCie BluRay burner installed A1 - Softwares "see" it and burn to it no problems..
My questions is: is there or not a way to burn my HomeVid recorded HD files (in m2ts) to a BD-re;
and play them on my new gen Samsung BluRay player like a movie ?
Im a newbie but i did a ton of research and seem to think it's not possible ?![]()
BTW - i used many diffrent programs and a few BD disks and believe i can write almost anything, but what will it take for the Player to either play individual files it sees on the disk, or play them like it would a movie.
Any help, comment or advice would sincerely be apreciated, thank you.
So far i used Roxio to burn the files....
What files do you have? if you have a BDMV folder it might work directly if you burn it. I would burn using Imgburn.
Or else reauthor(make a compliant blu-ray/avchd disc) your m2ts to a blu-ray/avhcd structure using multiAVCHD for example. -
Baldrick, THANK YOU !!!
Finally got my files to play just like a BD movie !!
I installed the avisynth update and isoburn like you said..A1
multiAVCHD is the way to go...exactly what i needed...!
thank you again !
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
What video/GPU chips do home Blu Ray players use?
By Moontrash in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Dec 2011, 11:43 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 23:04 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 13:48
