I think I know what you mean, and my apologies for being "thin skinned", but when I say processing, I do mean processing, it is not like I am never wrong, but I do mean what I say, and I am somewhat strict in my nomenclatureOriginally Posted by neomaine
I feel that you are a pretty bright dude, I don't wanna' fight w/ ya', that is counter productive, we are both here for the same reason, to help ppl, this does seem to be a war of semantics, you are the better man for saying so first, but to be honest you were "blowing me off' when I was technically correct and making a valid point
I will put that all in the past, you are helpful and that is appreciated, when I first commented it wasn't to dispute you, it was to point out an "exception to the rule"
I built and sold custom Gaming Rigs and tricked out HTPC's 9 years before I took my first PC class, and you know what? I learned a lot, and had a lot of fun
Although my field is Automotive Engineering, and my PC skills are purely a "feather in my cap", I went back to school and took a 6 credit PC hardware class this past fall to brush up for my A+ exam and even though I was in class w/ some beginners I still had a lot of fun, I got to help ppl and learn a few things (1 thing I learned is you sometimes have to put down the wrong answer to be right on the A+ exam)
for example: Where is the memory controller? On the cpu of course on all modern cpu's right?, but the A+ exam still wants you to say the north bridge lol
Do I need Computer certs to add to all my dozens of others?, of course not, but in this day and age of uncertainty, everything counts
May peace reign
ocgw
peace
Results 61 to 73 of 73
i7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Is that the 32bit or 64bit version?Originally Posted by JohnnyMalaria
My Viper is the 64bit version -
Ditto... I'll consider that a hand shake. ThanksOriginally Posted by ocgw
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
No hard feelings lol
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
Depends on whether you need > 4gb of memory. Now, if there's heavy processing..... No wait, ocgw has the experience with the auto stuff. Ocgw, whadda ya think?Originally Posted by stiltmanHave a good one,
neomaine
Okay, now that we are done pissing on each others cheerio's
I am going to use (actually already am) Vista Ultimate.
Which version would be better, 64bit or 32bit ?
As in, for the moment are there really any advantages to using 64bit over 32bit ?
Besides running 64bit programs, which as far as i know, i am only using 32bit programs.
Pretty much any common video encoding & editing program, mid to highend, latest photoshop, ect. -
Just stick with the 32bit version
Then buy the 64bit version of the Viper
Well i picked up both the other day.
Did a search on CL & Ebay & found someone locally who had the OEM set that included both 64 & 86 (32bit) for way cheap.
I installed the 64bit version first, messed around a little bit, then wiped it clean & installed the 32bit version.
But i am not into actually installing a lot of programs yet or transferring files or HDD's yet so it's no problem to wipe it clean again and use what i decide to use.
I prefer the 2-bit version myself
oh wait... the rest of the world calls it a V-Twin 8) -
Phew. Glad I eat PopTarts in the morning....Originally Posted by Noahtuck
I'd go with 64-bit.
Pros:
- Though your current software is 32-bit, you still get the advantage of OS operations (memory, disk...) using 64bit. (This probably more than offsets any slight disadvantage of running the 32bit programs under 64-bit.)
- Your 32-bit programs will still run AND you have the option of got to 64-bit versions when/if available without an OS change.
- No need to mess with the decision later. 64-bit has been tried and tested and seems to be overall pretty stable.
Cons:
- Driver availability for 64-bit.
- Software compatibility for Vista.
If you can get past those two cons, then everything should be pretty good.Have a good one,
neomaine
I'd try out Win7 64 bit. The XP mode emulator for it was release as RC1 recently:
http://www.microsoft.com/windows/virtual-pc/download.aspx
From what I've seen so far Win7 is what Vista should have been. The biggest issue is the availability of drivers for capture, and other, devices. -
I recommend Vista x64 or Win 7 x64 too, preferably Win 7 x64, driver support has been pretty strong for Win 7, Creative labs, and Hauppauge came thru early
Media Center 7 still needs a lil' work from my experience w/ Build 7100, supposedly all it's issues have been worked out w/ the RTS
ocgw
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 20Last Post: 19th May 2014, 12:55 -
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
Why is virtualdub 32bit much slower on windows 7 X64 than winxp 32bit?
By TigerSoul in forum EditingReplies: 4Last Post: 26th Mar 2010, 15:13 -
Q's on partioning a hdd and dual booting XP/vista 32bit and win 7 64bit
By Rudyard in forum ComputerReplies: 0Last Post: 14th Feb 2010, 19:52 -
Windows Vista - 32bit or 64bit?
By HatchetMan in forum ComputerReplies: 29Last Post: 12th Jan 2008, 00:24
